Mid-range question
I run some mbquart Q series up front only and with 250rms going to each of them they get LOUD and sound really nice doing it, I found most the parts on ebay rather cheap.
what are your goals with the speakers? what range do you want them to play? what size(s) can you accommodate? note the frequency response is 125Hz - 10kHz. are you going to run an active three-way system?
I was going to build a custom console to put them in, i was going to use a re audio 800 watt 4 channel amp no to the three-way mainly highs though and i want 6" or 6.5 no bigger.
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
748
gain set well below "Normal" and base boost is off completely
15
That was something I was going to try also to remove some of the gasjet from the front
Teezy
Teezy
Ellenwood, Ga
Teezy
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
