"Mini/Compact" Amps
Backdb78
Tried using the search function and didn't really find much in regards to what I'm looking for.
I'm building a pretty specific project that isn't car related. It requires a mini amp or compact amp, whichever term works better. I've done some fairly extensive testing and have definitely come up with what I don't like and only two that I do.
The DS18 Candy Micro 2 was perfect but they've discontinued that amp and what was left of them are gone.
The soundstream double-shot is close performance wise to the DS18 but doesn't put out quite as much volume. The RCA input plug that goes into the amp is extremely flimsy and I can see this being a problem point.
So essentially I've come here to see if anyone knows of an amp that exists that would be no bigger than 3.3'"x5"x1.5". I realize this is pretty hard to do so if I've already discovered all of them it's no biggie.
There are tons of these little micro amp boards around.
I just received in the mail an amp board similar to what pop just posted. The one I got is the bigger tps3116d2, which is basically 2 of the 3116 boards combined into 1. That Dayton puts out a legitimate 50 watts rms total, or 25 watts rms x 2 though. Nice little amps for projects.
I technically need a marine amp but for sure a car audio amp not a home amp. My biggest concern with those parts express amps is the reviews on longevity and quality are pretty iffy. Is there a way to build an enclosure for those amps?
http://rover.ebay.com/rover/1/711-5...0001&campid=5335951755&icep_item=160935353388
Total Power: 100 Watts
Max Power @ 2 Ohms: 50 Watts x 2
RMS Power @ 4 Ohms: 25 Watts x 2
Frequency Response: 20 to 22000 Hz
Total Harmonic Distortion (THD) @ RMS Output: 0.01%
Signal-to-Noise Ratio (SNR): 90 dB
Minimum Speaker Impedance: 2 Ohms
Dimensions: 1-5/8" x 4" x 3-1/8"
I know its a SoundStorm. But for the price its worth a shot
https://www.sonicelectronix.com/item-137717-MTX-MUD502-Open-Box-Complete.html
General Features:
  • MTX MUD50.2 Power Sports Amplifier
  • Class D Full Range 2-Ohm Stable 2-Channel Amplifier
  • RMS Power Rating:
    • 4 ohms: 25 watts x 2 chan.
    • 2 ohms: 50 watts x 2 chan.
  • Total power output: 200 watts
  • Weather Resistant in Accordance with IP66 Rating
  • Conformal Coated Printed Circuit Board that Resists Moisture
  • Pigtail contains all wiring necessary to connect power, ground and signal
  • Pulse Width Modulated MOSFET power supply
  • Speaker-level (high-level) inputs
  • Input sensitivity:
    • Low level: 200mV-5V
    • High level: 400mV-10V
  • Frequency Response: 11 - 40,000 Hz
  • Total Harmonic Distortion (THD): <1%
  • Signal to Noise Ration: <75 dB
  • Fixed high-pass filter: 80 Hz, 12 dB/octave
  • Fuse Rating: 7.5 A
  • Dimensions: 1.73"W x 2.85"L x 3.64"H
I love my little NVX MVP1A sub amp
Tiny, dirt cheap, super efficient and pushes my JBL 12 with ease
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Ch 1 and 2 can be bridged and 3 and 4. The amp shows you where to put the speaker wire to bridge it. It becomes a more powerful 2ch.
32
6K
Backdb78
Backdb78
United States
dragon.breath
    Jun 1, 2024
    May 31, 2024
