Mixed Ohm subs
  • 4
G0ssam3r
Ok I have 2 10" Pioneer IB Flat shallow mount, and 1 Alpine Type R full size running off a 2000w mono block amp. The Pioneer's are 4 ohm the Alpine is 4/2 ohm. Right now I have them wired at 4+4+4= 1.5 ohm. My question is would it be better to continue running this setup or switch the Alpine to 2 ohm so I would have 1 ohm at the amp? Would there be a noticeable difference between 1.5 ohm and 1 ohm at the amp?
Right now you are at 1.33 ohms. If you wire the alpine to 2 ohm the power would be divided 1000 watts to the alpine and 1000 watts to pair of pioneers. Whether the amp is actually 2000 watts is another variable. Mixing subs/sizes/impedences normally has a negative affect on performance opposed to actually gaining much. Especially in a shared enclosure.
It also lowers the amps efficiency and raises the current draw.
424
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
281
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
978
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
G0ssam3r
G0ssam3r
Lexington, Ky
jigsizzle
    May 12, 2024
Brendon Jenness
    May 11, 2024
