MPI's 2002 Ford Explorer
MPI
So my original plan has changed a bit... The original plan was to only change out the Sony amp and put in a Rockford mono and a Polk 4 channel... it has evolved now into a full blown replacement of everything... up in the front doors are a pair of Polk 5X7's, the rear doors Polk 6X9's, and in the back sits a pair of Polk 12" subs in a ported box... along with a new Alpine iDA-X305S head unit and new 4 awg wire for the amps... I ended up returning the Polk PA660, deciding to go with all Rockford amps instead. So amp wise now the idea is to have my punch P500-1bd run the subs (possibly buy a second in the future) and 2 Rockford P400-2 channel (one for the front, one for the back) and then I have 3 monster 1 farad digi caps... Im mounting the amps and caps on a white Plexiglas panel in the back of the explorer, and under them, edge glow blue Acrylic with LED's
So my original plan has changed a bit... The original plan was to only change out the Sony amp and put in a Rockford mono and a Polk 4 channel... it has evolved now into a full blown replacement of everything... up in the front doors are a pair of Polk 5X7's, the rear doors Polk 6X9's, and in the back sits a pair of Polk 12" subs in a ported box... along with a new Alpine iDA-X305S head unit and new 4 awg wire for the amps... I ended up returning the Polk PA660, deciding to go with all Rockford amps instead. So amp wise now the idea is to have my punch P500-1bd run the subs (possibly buy a second in the future) and 2 Rockford P400-2 channel (one for the front, one for the back) and then with all this power I got 3 monster 1 farad digi caps... Im mounting the amps and caps on a white Plexiglas panel in the back of the explorer, and under them, edge glow blue Acrylic with LED's
no way man pics please this sounds bad a$$ //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
my custom made Cap holder (still need to sand/buff edges)
The first panel... if any one with a Polk PA660 and a Rockford P500-1bd or P400-2 want to buy it hit me up...
just kinda figuring out placement of everything... and I just ordered the two P400-2's!!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well i wanted to make my own holder because they will have LED's under them as well and I didn't like the cheap ones that come with... solid cast acrylic just looks far better than cheap Chinese injection molded crap.
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
635
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
MPI
MPI
Milwaukee
j&b4ever
audiobaun
    May 19, 2024
    May 19, 2024
