MPI's 2002 Ford Explorer
the cap isnt going to help your voltage drops... get yourself a good battery and do the big 3, if that doesn't work, get an alternator. caps are a waste of money.
i dont have any caps with 6k rms because they aren't necessary... just build the charging system properly.
not to be a **** or anything, but it seems like a lot of trouble to go to to make so-so equipment look nice.
well I don't really care if im building a so-so setup, and it isn't really a lot of work to make custom plexi stuff because I work with plastic all the time. I didn't set out to build a competition grade system, just something fun that looks nice
Just a fyi. Capacitors don't help you or your car at all. if anything they make a weak electrical system worse
what he said //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
625
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
MPI
MPI
Milwaukee
j&b4ever
audiobaun
    May 19, 2024
    May 19, 2024
