Multiple amp grounds
  • 3
Jimg
CarAudio.com Regular
217
13
If running a 2-3 amplifiers system
and a dsp
After market headunit
1 Does it matter if they are all grounded at the same place with a grounding block
vs each having a ground at their own locations.
2. or is this just a have to do what ever option it takes to not have ground noise in the system
I have one wire going to the grounding point and then use a grounding distribution block sending out the ground to the amplifiers and soon the DSP when I install it. Never had an issue doing it that way for years and years. They make specific distribution grounding blocks.
I think you can test the voltage drop at different points in your electrical system. You can test your ground, I watched a nice video about it by (guessing a little here) CarAudioFabrication on YouTube.
A good ground will have low voltage drop? Or very low resistance?
But its a legit way to make sure your grounds are doing a great job.
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
6
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Jimg
Jimg
Jimg
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
