Multiply one signal??? Help out a newbie plz
  • 4
Xesar1988
Hi guys, i hope my questions dont sound dumb to some of you guys that have been in the game for a long time. Im a newbie in car audio and im starting with one of hardest cars to do so. (Encore bose ans) anyways my question.
Bypassing factory amp. I found the low level signals but the signal to the front door speakers is more of a full range signal than back doors signal....is there a way to use the front door signal for both back and front??? Multiply that signal
Thanks in advance guys ive had hard enough time trying to figure out this car has been a real pain in the *** and the head u it really ***** allready.
are u saying back speakers don't play as high freqs? is so probably factory crossover, lot of us don't even use rear speakers so if thats what u mean i'd just leave it is..
Hi guys, i hope my questions dont sound dumb to some of you guys that have been in the game for a long time. Im a newbie in car audio and im starting with one of hardest cars to do so. (Encore bose ans) anyways my question...
what kind of car is it? and i agree with gramps that if the signal is different at the front than the rear, its probably a factory crossover. may have to get a dsp to achieve what it sounds like youre wanting to do
There are more than a few processors that will allow the use of just one left and right input while putting out like six or eight channels to your different amplifiers.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
Xesar1988
Xesar1988
Kissimmee, Fl
Xesar1988
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
