My entry level budget system......... Any recommendations ?
six6nine9wpk
16
Wash, DC
I'm the owner of a 2003 Chevy Avalanche. I have done hours and hours of research on the web, so that I could get the most out of my budget. This is the system that I have put together. Tell me what you think..........
Front Speaker
JBL MS62C 6.5
•RMS Power Range: 80 Watts
•Peak Power Handling: 180 Watts
Rear Fill Speakers
JBL P652
•RMS Power Range: 75 Watts
•Peak Power Handling: 250 Watts
4 Channel Amp
Soundstream REF4.760
760W RMS 4-Channel Class A/B Reference Series Power Amplifier
125 X 4 @ 4-Ohms
10' Subwoofer
Sundown Audio 10" SD-2 10D2 Dual 2-Ohm Subwoofer
500rms @ 2-Ohms
Mono Amp
Hifonics 1500W Class D MonoBlock HF Series Car Subwoofer Amplifier (HFi 1500)
750rms @ 2-Ohms
I would like some of you guys opinion on this system and if there is anything you would change let me know.
1000........ dollars. I have a 6 channel JL Audio G6600 but its under powered at 75 x 6 @ 4ohms. I don't want to under power my subs or yearn for more later on.
I'd ditch the rear speakers, apply that money toward a front set that has some real mid bass. Something like a PHD FB pro set or...
and if you really want some speakers for the rear, go cheap (& good) like a set of Silverflutes mids only.
Having the SS ref amp for the front.....why not use the ref 500 for the sub?
Much better amp vs the HFi 1500....
and x2 on ditching the rear speaker idea....just use the factory speakers and fade them down for "fill". Use the ref 4ch to run your front components active
and you will have a very nice "entry level, budget" start!
Factory. 2021 Chevy Silverado custom trailboss
9
561
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
666
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
584
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
six6nine9wpk
six6nine9wpk
Wash, DC
SamIam71
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
