My little project
  • 4
Nice bro, how do like that amp? I've been looking into MB Quart amps as they accept balanced differential inputs.
They alright hows that..how do you like that 540i? I wrapped my sisters around a tree about 6 months ago
I'm impressed, they DO have power. I haven't had them clamped. The first one I got a DSC 1500.1D and it magically burned out. Maxxosonics replaced it with this ONX, but guess they didn't know why the DSC just randomly quit working. I'm pretty sure it's not from anything I did.
So basically maxxosonics traded out the cheap DSC (which did have power when it worked) for the ONX.
I'm impressed so far, it's holding up and definitely able to overpower these alpines.
As far as the price? Well, I was told there's better ones out there.
I am loving it, the torque is awesome. It's very responsive. It's so much fun on the interstate "I'll be driving at 60,then floor it (in 6th gear) and OMFG where'd all the cars go???:D"
Hmm thanks for the info, it'll be at least 2 months before I look into buying and I'll ask you how it turned out before I pull the plug.
I wanted to ask you which is better in efficiency, sound quality, and spl? The MB Quart DSC1500.1d or MB Quart ONX1500.1d? And does the DSC1500.1d overheats? Reason im asking, because i have the same amp DSC1500.1d and wanted to know from a owner of it how does it compare. And this is the second time i heard of this amp going out. I hope my don't.
I wouldn't know the difference.. The DSC quit working before I could ever put it through intense work (so to speak). Kind of odd if you ask me. The ONX is still performing like a beast.. I still need to figure out my subsonic levels, LPF and whatnot though.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
940
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
robertark
Alpine Fan
robertark
Overland Park, Kansas, United States
robertark
