My newest SQ Amp.....
I would venture to guess that the Butler is not a true tube amplifier and that the tubes are just on the pre-amplification or some other stage. Why do I say this? Because 4 x 75 watts with 80 amps of fusing in a 12 volt environment for a true tube amplifier doesn't add up.
I decided to break the bank and order one of these bish's ....//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif Time for a new SQ build //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Butler Audio
jokes for days
You picked a tube amp for an SQ installation when tubes tend to have more distortion than regular amps?
That warmth people hear in tube amps IS Distortion //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you sir are correct.
TUBE DRIVER BLUE
The ONLY USA-Patented and Authentic-Sounding TUBE HYBRID CAR AMP!!
Would you really want to be in a car with a true 300w tube amp in the trunk? You could bake cookies while you listen I bet //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
96
344
  • Locked
647
Amp
475
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
    May 31, 2024
    May 24, 2024
