Need $100 comps.
Sounds like a poor tuning issue. You can literally make any set sound good with proper signal processing/tuning, speaker placement, acoustical door treatment. There's more to sound quality then to just buy a set of speakers and toss it in on the door with an amp then playing around with the EQ
What Size? 5.25s or 6.50s.Ill say this..I have a set of Polk DB 6.5 coax, that have lasted me for the last 3 yrs, and they sound excellent on HU power and sound fantastic on 50+ rms with preped doors.They get loud and play very clean on a good clean ,low tdh amp..Infinity are very nice as well
6.5s, and I know there's more to it than that, this is just all I have.
If you know, then you should not pass off speakers just because you heard them in an improper setup. A pair of flea market speakers can be made to sound better than 200$ components if the install, tuning, processing, deadening etc are done right while the 200$ components are improperly setup.
Polk audio db comps. I ran them on double rates power for years with no issues. Sound great and kept up with 150db + ad they are weather resistant
I really like Polks, they have been around for a very long time,and do sound very good for the money..JBL, and Infinity also
We pulled a set of Polk MM crossovers out of a door the other day. They where in a bag that was filled with water that looks like it was there for at least a year. Still worked
There is a build log going on of a Charger/Ramrod that has some experience with the NVX speakers that can give you his experience of using them to get some feedback on how they sound/perform
Well I didn't spend $1,500 on my system. I only have $50 and 36 hours of labor in my sub setup. I have an Alpine MRV-F345 on the way, and I need component speakers for that price. If you aren't going to help me with what I'm looking for, don't reply. Thanks.
so your labor is worth nothing? I wouldnt work for 36 hours for $1550.
that said, I did help. im trying to help you save money by not buying GARBAGE
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
113
184
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
137
489
Brian21699
Brian21699
Vancleave, MS
Brian21699
audiobaun
    May 19, 2024
    May 19, 2024
