Need a new amp for a Brahma 15
  • 3
low00ranger
USA
I'm looking for recommendations for a new amp for my Brahma 15 that I'm going to put in my Magnum. I am using a 2.0 cubic feet sealed box so I have more space for junk. I'm looking for about 800 watts and I mainly listen to metal. So I want tight and accurate bass. Not reference-SQ quality but something that doesn't sound muddy. Also, the Brahma has dual 2 ohm voice coils so I need that 800 watts at 1 or 4 ohms.
What you guys got for me?
If your going to save space and go sealed you might be better off with a different sub.. just saying. Would you be interested in selling the brahma?
I am open to using a different sub, do you have suggestions? I was just going to try it since I already have it. If I don't use it in my car I will continue using it in my home theater setup. It is worth more to me than I can sell it for!
11
850
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
low00ranger
low00ranger
USA
mylows10
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
