need a pair of 6.5 coaxils that i can run off a ppi .900.5
  • 3
brandonkain82
your mom goes to college
Looking for a set of 6.5 coaxils....running off a ppi 900.5....its for a work truck so im not looking to spend more then 100.00
Item(s) for Sale: Looking for a set of 6.5 coaxils....running off a ppi 900.5....its for a work truck so im not looking to spend more then 100.00
We have CDT COX 622 we can get you for cheap. Ill text ya.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
161
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
118
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
464
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
357
brandonkain82
brandonkain82
frankfort,il
Vertex Audio
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
