Need a recone on a HDD 15 inch tantric sub.
Im thinking about proving a point tomorrow and sealing up one sub hole, and running the good sub at .7ohm.. Im 99% sure it will stay cool even with a 2.4k on it alone. I will not even change any settings..The subs are known to take 2.5k each with clean power...So I was told...I do have a singer alt that puts out 370 amp peak so 14 volts is not a prob. Thanks for the alt hook up Jim. If the good sub takes 2 times the power and stays cool there was a flaw with one.....The plan was to run 4 AQ 2200 strap 2 to each sub, but thats gona happen with these coils i have..
450
355
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
393
ptcruiser07
ptcruiser07
TX
disturbed471985
    May 31, 2024
    May 24, 2024
