Need a second battery for my truck
  • 5
Trancer
Allen, Texas
Hey guys, I have been looking at the car audio battery classifieds and found some batteries that I like. I have never installed a second battery so I dont know much about them. I have tried to read up as much as I can, but the whole amps to hours and other specifications just confuse me, so I apologize ahead of time
Here is my current amplifier setup
Audiopipe 30001D (This will be running at its full potential once I get my 4 8's in) Power Hungry amp
Audiopipe AQX-360.4 (125w x 4 @ 4 ohm) Class A/B
Other electronics
Rockford Fosgate 3Sixty.1 (This shouldnt be drawing much current) its just a Digital Sound Processor
400 watt Power Inverter (I only use this for my 105 watt power supply for my laptop from time to time
My current Electrical
Big 3
DS144 AC Delco Alternator (Not sure if its 140a or the optional 160a alternator
My factory battery is small. I think its a 650CCA battery
I will be getting a Mechman 270a H.O. alternator. There is a guy on the message board selling one, but he doesnt know the model number so Im awaiting to hear back from him on if it will fit my 2 pin 5.3l Vortec V-8 for my Sierra. (Silverado is the same)
So these are the dimensions I have for my accessory battery tray
10.9" long x 8.5" tall x 8.5" wide
These are the batteries I have found
The Stinger SPP1500D is the front runner in my battery options. It has the most amount of hours of discharge
Stinger SPP1500D (On ebay for $269 free shipping, but might be able to get it cheaper through my dealer)
Dimensions: 10.28" long x 6.75" wide x 7.19" tall (This would fit my accessory battery tray perfectly)
PDF manual
http://www.stingerelectronics.com/images/pdfs/2SPP1500d.pdf
C&D 102ah Battery (model # UPS12-400MR) $85 + shipping (Used)
Its a bit longer than my accessory battery tray, but I may be able to make it fit
Dimensions are: 13.5" x 7" x 9.5".
Here is the PDF for the C&D Batteries: http://www.wilsonengineered.com/Literature/CD/High_Rate_Max_Brochure.pdf
XS Power D1400
Dimensions: 10.24" long x 7.2" tall x 6.65" wide (This will fit no problem)
Couldnt Find a PDF Manual, but here is the battery from XS's website
D1400 « XS Power
C&D Dynasty DCS-100L AGM battery (Used for less than a month. Selling it as BNIB for $150+ ship)
13.42" Long x 6.8" Wide x 9.48 tall (Will need some modifications to fit)
PDF for the DCS-100L
http://www.cdtechno.com/pdf/lit/dcs_100.pdf
Deka dual post 105ah (Used for only 2 months and wasnt used that often. Selling for $150 + shipping)
12.94" long x 9.38" Wide x 6.75 Tall (I think I should be able to get this to fit)
PDF Spec Sheet
http://pvpower.com/uploads/products/8a31dtspec.pdf
So what do you guys think?
i can do a c&d 400mr for 135 shipped bout a year old holds charge at 12.78
If you read the post, I got a guy selling his C&D 400mr for $85 + shipping... Fedex shows $43 for shipping. So that would be $128. If you can go lower, I will consider it once I get some feedback from some people on which battery would be best for me.
im pretty sure i can beat it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif lmk
Will do. Thanks!
If you can give an unbiased opinion why the your battery would be better than the others (exclude pricing into consideration) that would help.
Like I said,
I dont know about all of this amperage, discharge rate, amperage at hours, etc... so Im so confused on what is the better deal and better option
Will do. Thanks!
Like I said,
unbiased IMO its the same as any other 100ah batt.
i had a buddy of mine go froma d3400 to one of these and saw a little gain. other than that most people i have sold to havent told me how they have helped or what they would compare them to
unbiased IMO its the same as any other 100ah batt. i had a buddy of mine go froma d3400 to one of these and saw a little gain. other than that most people i have sold to havent told me how they have helped or what they would compare them to
Thanks for your unbiased opinion. I appreciate that.
Why pay for a name when its just a batt?
I have plenty of buds who have used all kinds of batts and XS outperforms them all...they are good batts just expensive. They are the sundown of battery manufacturers lol
173
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
127
471
363
Trancer
Trancer
Allen, Texas
Trancer
    May 18, 2024
    May 18, 2024
