Need Amp(s) for 4 Type Rs
Fate710
Alright well i'm tryin to find 4 Type Rs in the 12" flavor and I have found a few sweet deals that I'm considering. But I'm needin something to power these suckers. I would like to either run 1 amp per sub or 1 amp per 2 subs. I will run 1 amp for all 4 if it will do it. Please help a guy out.
(2) ED Nine.1 1200 @1ohm $700 but they run alot of sells
(2) Re Audio 12.1 1200@1ohm
JBL Power BPX2200.1 2000@1-4ohm (Underrated) $1500
Kicker KX2500.1 2500@2ohm (Underrated) $1500
US Amps AXDD 2600@2ohm
(2) US Amps AX1000DE 1000@1Ohm
Remember this is going to be part SPL setup and part show setup. The show setup I can take care of but I want enough power to be competitive
I was going to just use 2 of my susb during daily use and then use the other 2 during comps. Have a switch I guess you could say. 1250 to each of them is tooo much for daily though? even with gains low low low?
You could set the gains low, like set the gains low enough so that your normal driving volume only gets like 800 watts out of the amp. Depends on how many amps too. For 2 orions you could get dual 2 ohm subs. wire the subs series all of them, for 4 ohms a piece, parallel a pair to each orion for 2 ohm load and something like 1200-1400 watts per pair of subs. Then for comp wire the subs down to 1 ohm load each, .5 ohms to each orion amp for a hella lot of power. This is what I would do, I've heard those subs can take serious amounts of power on burps anyhow.
Or if you wanted to run just one orion amp, you could get dual 2 ohm subs, wire them all series 4 ohms ea, then parallel to the amp for 2500 x1 at 1 ohm for all 4 subs netting about 625 watts each.
I like the idea of have them between 1200-1400 per pair of subs. I would just leave it @ that. I won't compete very often(I don't want to do meca and IASCA and dBDrag have very few events around for SPL) but when I do compete I could rewire them no problem.
davesexplorer pm me so we can work something out
660
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
964
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Fate710
Fate710
Indianapolis, IN
Fate710
    May 18, 2024
    May 16, 2024
