need amp suggestion!!!!
  • Thread starter <frank>
  • Start date
  • Replies 3
  • Views 2K
  • 2
Depending on your budget - I'd go with a punch 1000 or punch 800. There are tons of decent amps to run those, but Rockford is a very good way to go. shopping on Ebay can get you great deals - or a crappy amp that you just bid too high for. Try etronics.com - very good deals on new Rockford amps.
You might also want to check out the JBL1200 It's a good stable amp that's pretty cheap. I also like the fosgate amps. I'm running a BD1000.1 to a pair of HX2's myself.It Pounds
11
660
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
964
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Guest
BigAudioJoe
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
