need an amp for 2 hx2s
  • Thread starter <jon>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<jon>
Guest
im lookin for an amp to power two rockford punck hx2s. they are 500 rms and 1000 peak. i may later want to get a third one so if you could help me find an amp that would power three that would be cool. thanks for any help
Are they the dual 2ohm rfd2112 or the dual 4ohm rfd2212 ? If they are the dual 2ohm I would suggest an amp with the max power output at 2ohms like the fosgate BD series,MTX Class d, or the JBL Class d. If they are the dual 4ohms you will want an amp that puts out max power at either 4ohms or 1 ohms. Again the Jbl will work in this situation. I would say go with the JBL due to several factors one being price. Second being performance.
852
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Guest
ramos
    Jun 1, 2024
    May 31, 2024
