NEED assistance on COMPONENET SPEAKERS!!!!
i have 1 12" apline type R sub and the base is riduculous. all i hear is the base, cant even hear the highs. thats why im thinking of getting a component system. Ima need a another 4 channel amp to power it for sure. the questions i have is that will i be able to run the tweeters, mid-range and my rear factory speakers on the amp? i was thinkin ill have to run the rear speaker thorugh the receiver. for example i like this component: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15058
in the review, the people talked about getting two sets of it. it just got me confused. also, the impedance is 4 ohms, the kicker in the link says it has 75watts rms, so this would mean i need an amp that has 75+ watts rms @ 4 channel?? if theres someone that could help me out i will really appreciate it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There is a cheaper line of rainbows as well at ~$240... and I'm not sure why you need a 4 ch amp unless you plan on "going active" which I wouldn't do unless your experienced with car audio. Find a decent 2 ch amp at around 75 or 100x2 and a set of Rainbow Comps (PM 6spdcoupe for prices) or something else that meets your fancy... that should be a good start.
ya people seem to like the type r 6.5" components, and get an amp that puts out about 150w x2 at 4 ohms. then run you rears off of your deck.
i like the type r comp. since my sub is type r might as well stick with it. i found one for $125 on some website, Alpine SPR-17LS, then i checked to see if it fits my car and it says no. theyre 6.5" so im thinking they should fit a mustang.
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
412
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
487
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
374
Young Gotti
Young Gotti
Long Beach, CA
Young Gotti
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
