Need Build Assistance
  • 1
LSXGTO
Looking to fix/upgrade audio system in 05 GTO.
Front L/R Tweeters: Stock
Door L/R Speakers: Rockford Fosgate R165x3 6.5in 3-way Coaxials
Rear Seat Door Panel Speakers: Rockford Fosgate R165x3 6.5in 3-way Coaxials
Rear Deck Speakers: Stock
Trunk Amp: Stock
HU: JVC KD-AVX77
I'm far from an audiophile. The head united was installed by the previous owner. Reason for replacing is that all of the speakers tweak and are audibly broken at a certain volume. I replaced the door and rear side panel speakers hoping that would fix it. Turns out the tweeters still tweak and need replaced. Also the car lacks significant bass.
The Rockford Fosgate speakers were a cheap fix to attempt to fix the broken audio system.
Don't need an audiophile setup, but being able to turn up the speakers without worry that it will cut out or tweak, while still having bass is my goal.
The tweeters are getting replaced, as they are broken.
Do I replace the rear deck speakers to something with more bass capability or would this not create a significant difference? Do I need to add a amp/sub? Do I need to do both? Do I need to toss the Rockford Fosgate speakers and head unit and start from scratch?
Preferably the less work the better, so if I do not have to figure out how to install an amp/sub then I won't. Pretty much the entire interior of the car is going to get taken out in order to get to all of these speakers, so I figured I'd post and ask you guys before I do so to get some help. I'm not on an extreme budget, but I don't need to blow my wallet on some speakers for a car (the Rockford Fosgate speakers I bought were $35 a pair on amazon). If I need to spend a little more to get some better stuff that isn't junk then let me know please.
If you need any other information I'll try my best to respond and add it, but I just typed this up real quick hoping to get some guidance of what I should go with and do.
Thank you.
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
969
JL has some slim subs, maybe one of those will fit. Alpine has some pretty small amps, you could put that/those under the passenger seat? i like...
952
LSXGTO
LSXGTO
LSXGTO
    Jun 4, 2024
    Jun 3, 2024
