Need Help/Advice on Bass Setup.
Thanks for the advice! Should i get a soundqubed 2200.1 amp for this sub?
Its one of the cheaper ones amongst the good quality amps.
Actually man here's a killer deal, this amp is normally 399$, its now 230 shipped which is only 30 above your current budget.
or if you wanna try something new
http://www.amazon.com/FSD-Audio-3800-Watt-Monoblock-Amplifier/dp/B00WZUX0VY
for your alt, hit up j's ultimate alts, excessive amperage, ohio generator, singer, mechman and DC power. As long as you have the alt, the big 3 upgrade and XS power batt, you should be able to get a D1 hdc4 15 and run at half ohm, amp's half ohm capable.
Any plans for a custom box yet?
This is a chart from a well known soundqubed fanatic/expert/160db+ competitor aka Andrew McCullough, owner of The Black Nasty on youtube.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
128
11
707
753
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
972
skaterboyjt97
Roanoke, VA
Jeffdachef
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
