Need help asap
  • 4
What's the best box to build for 3 kicker l7s with about 45x50 inches to play with
Best box?.. that's pretty vague. This went into a Dodge Magnum and pounds.
I suppose it could have been bigger but the vehicle had space constraints and its getting a Korean 4K wired .67 once his electrical is solid so it's sized about right imo.
You always have some nice specs for enclosures man.
Perfect
the resistance is fine, and the fuse as well. I just replaced the ground connection when I first had the problem with the subs cutting out, it's...
46
673
736
964
Mikey0075
Mikey0075
S.c
Mikey0075
    May 18, 2024
    May 18, 2024
