need help car stereo wont turn on
there is your problem. It shorted out I have done the same thing. I luckily had crutchfield support id the exact fuses to check. Its a fuse you just are looking in the wrong place. my car had 3 different fuses that could short out and it only blew one that was named cigar. Who knows man. It will be a pain but you need to manually check every fuse.
is there another location for fuses? 13 fuses doesnt seem like thats all the car would need even if it was that old. There must be a different fuse holder location. I would also check your grounds. Another easy test is get a volt meter and check your constant and your ground.
489
857
863
rigsboo
rigsboo
marion va
rigsboo
maylar
    Jun 2, 2024
    Jun 1, 2024
