Need help deciding on amp
sa 12's need 700-1200rms per sub so no.. small 4 chan 50-75x4 and a decent mono amp be tons better.. wolfram 2400 will push those sa 12's they $250.. the 5 chan at best would push 1 (i guess the amp does rated at ohm so would need 1 d4)
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
644
712
955
xtyler855
xtyler855
Mississippi
Clifff150
    May 16, 2024
    May 16, 2024
