Need Help? Let Me know
Thanks for helping me with my system, i learned a lot //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Another glowing review here for Matt's work and great personality. I'm about to post the first set of pics/descriptions for our long 12 hour or so day today - day one on my '08 CR-V overhaul - but wanted to say - like everyone else on this thread who has worked with him - if you need some great quality work done (e.g. not a "hack" job like I've had at certain big-box stores), it's worth your time reaching out for him. Rare to find someone so generous with his time to actually TEACH you things while working together on a project.
Okay...prepping pics to upload to the build forum. I'll try to put a link here to that detailed thread once I have it posted.
-Adam
Another install was done the direct link here " http://www.caraudio.com/forum/showthread.php?t=454710 " It was a 2008 Honda CRV came out great. I will not say much more as the customer "Adam" said most of it.
Directly from him
Today was the first day of my '08 CR-V's metamorphosis. With the help of forum member bigaudiofanati2 (Matt) - who I can't recommend highly enough whether you just need questions answered, want to hire for a build or to work along with and learn something at the same time while having things installed well (e.g. good solder skills, and methodical). We started with my car:
'08 CRV LX, with Pioneer DEH-7000BT I previously installed (together with bluetooth, external XM module, but everything else stock (speakers, no amps, no sub - blah blah sound with lots of road noise).
TO (so far):
Alpine PDX-5 5-channel amp; Polk MM6501 6.5" component system for the front; Infinity 6032si 6.5" for the rears. Also, 3-bulk packs of Dynamat Extreme, Kicker 09PK4 4AWG amp wiring kit and Monster MPC I306 6-channel RCA cable. The sub-choice remains pending (but will be powered by the PDX-5) - as I'm still considering either sub-box location or some way of integrating a shallow-mount sub or the like in the truck (without buying a $$$ JL Stealthbox; I'd rather be a bit more unique/custom than that).
Well, without further adieu, here are some pics from Day One. The dynamating was all my work, so don't hold any faux pas there against Matt, lol. I'll leave it to him to reply and detail the considerations he has taken so far on the build.
All new speaker wire was ran to the speakers and to the new tweeters. The original plan was to build up a mount with wood and bondo the tweeters into the sides of the doors. "might still do" but we will first test the system with the stock locations and see how it sounds and go from there. It would look slick and would probably give him better imaging. As I said still up in the air. Tomorrow I will be working on the fuse mount for the crv and painting that. Than Friday we will get back together install the amp either under the seat or in another location. As we have said we are not sure what we are going to do about the sub yet but it will probably be a custom box build. Which I will look forward to. Other minor things will be remounting the blu tooth mic. the sad part about this is that the pioneer is already producing a low wine noise "always with pioneers" so I will probably ground the rca's and change the ground point see if that helps. Might be changing the head unit but that is up to Adam and what the turnout is. It is going to turn out to be a good setup.
Did the fuse block bracket
Fuse mount looks good. Up here in North Jersey, I continued with Dynamat. Today, I think it was seven sheets in the trunk. Here are some pics before and after.
Tomorrow, big things happening. PDX-5 amp which was finally delivered being installed, dynamat to the floors/liftgate, mount the crossovers, bluetooth mic, put everything back together again the ... yeah, listen to and tune it.
Drove down yesterday to continue work with Matt (after spending the day before putting in my trunk Dynamat, as shown above). Wrapped up everything nicely - Dynamat to the floors, amp installed, custom fuse bracket and sheet metal bluetooth mic bracket installed. The Alpine PDX-5 is awesome - so small and the verification sheet from the factory - well, a pic is below; obviously they severely underrate the powerhandling ability of them. I'll let Matt fill in any details from yesterday i'm forgetting. Again, can't recommend working with him highly enough. Learned a lot yesterday and his attention to detail is very significant.
484
854
859
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
FreddyNJ
    Jun 1, 2024
    May 31, 2024
