Need Help. LOC or Not?
1chayward
I have 2012 F150 Platinum with Sony/Nav/Sync and factory Sub. I'm installing new door speakers all around being pushed by 4ch. amp and a new sub with mono amp. Both Amps have level controls, so would that act as a LOC?? If I do need one how many channels?
Rockford P400X1 Punch 1-Channel Mono Block Amplifier
Rockford R300X4 Prime 4-Channel Amplifier
Pioneer TS-A6886R 6" x 8" 4-Way Speaker x 4
Kicker 40TCWRT122 12" Single Subwoofer Enclosure
Check out an lc6i. It will restore the factory bass loss with the stock hu.
The amp has line level inputs -- basically small in line LOC's, which would work, but if you want to avoid the high volume bass attenuation a lot of stock radios do then yes, you'll need a line output converter -- one with bass processing like the Audiocontrol LC7i or LC2i.
489
860
865
1chayward
1chayward
Mississippi
1chayward
maylar
    Jun 2, 2024
    Jun 1, 2024
