Need Help,Noob Question Wiring 3 Amps, Two (4) channel Amps and 1 Monoblock
  • 3
LaidD3athl0rd
If anyone is interested please help.
I am new to car audio but i have always been interested, after just receiving my first car i am ready to start. Know the basics, just have a few questions.
I have currently 2 Amps Setup.
1x Clarion 800rms monoblock, powering 2 12" Pioneer Champion Subs.
1x Pioneer 4 channel, powering 2 front Alpine Type R splits and the rear 2 , 2 way pioneer 6" speakers.
I want to place another 4 speakers on my parcel shelf covering the boot, i drive a hatch and i want to tilt my parcel shelf forward when my boot is open to project music out the rear.
I clearly need another 4 channel Amp, can this been done etc .. i have 2 pre rca outputs on my deck and i should be upgrading to a better deck with 3 rca outs ( around 4-5 line volt).
Do i just connect Y splitters to my current RCA leads until i have split 10-12 connections into a final 3, for both red and white connections?
As long as i keep the reds with the reds, and the whites with the whites is this upgrade possibly?
Oh yes of course, thanks for this advice.
I don't have any experience in daisy chaining amps to one another, i would be daisy chaining the new 4 channel amp to the monoblock amp correct? ..
I have 4 rca outputs on my mono, 2 are master and 2 are slave.
What would be the purpose or benefit from daisy chaining the amps to one another?
Instead of using Y splitters and taking it back to the head unit.
first off, welcome.
second, if you tilt the parcel shelf forward, you want to have the speakers mounted to it in enclosures. you need to keep the rear airspace totally separate from the front airspace otherwise you get cancellation and just wasted effort.
third, yes, you can run three amps. getting signals to them is best done with a new head unit - buy that first. then, once you have a HU with 6-channel outputs, get your second 4 channel amp and rear parcel shelf speakers.
you don't want to split your HU outputs more than twice - because it reduces the impedance load and can damage the HU outputs.
if you want to keep your HU, then just get a line driver or EQ that has 2 inputs and 6 outputs.
if your 4 channel amps can run off 2 inputs, then you're set. if not, then you'll still need y-adapters at each amp. i recommend the kind with one female and two male connectors so the split is at the amp (saves cabling).
you did not provide model numbers so we cannot verify what your amps can or cannot do.
lastly, most 4 channel amps can operate at 2 ohm loads, so you can connect two 4 ohm speakers to each output (for a total of 8 speakers powered off on 4 channel amp). the result is a hotter amp - which can be an issue in warm climates. you also lose some ability to adjust level of each speaker pair/type as well as independent crossover for each speaker. i recommend you idea to have a second 4 channel amp - but in the meantime, you could try to run all 8 speakers off one 4 channel amp.
Thank you for your advice.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My 4 channel amplifier can operate under 2 ohm loads with 8 speakers but the rms output would be too low and not worth it per speaker... i am definitely going to run another 4 channel amp to maximize the potential of the new speakers, i am going for 2 ( 6x9's) and 2 (6"s), all in the parcel shelf.. this will give me a total of 6 speakers in rear of the car, 4 in the parcel shelf and the other 2 which are already in the side shelf's.
I don't think I'll have to worry about the airspace between the front and rear of the car because there are currently 2 speakers mounted in the side shelf's that i think sound amazing and don't interfere with my fronts. If this did become a problem i would just lower the speakers levels so there is a steady balance throughout the car.
My current Amps aren't very new so bare with me. i am very satisfied with them at this stage. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pioneer 4 channel GM - 6100F Amplifier
And
Clarion DPX 1800 Mono Block Amplifier.
11
657
722
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
957
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
LaidD3athl0rd
LaidD3athl0rd
South Australia
LaidD3athl0rd
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
