Need help on amp for highs and mids
  • 2
well firstly how is the crunch amp doing on the 6x9's so far? No need to fix it if it isnt broke! For the 4x6's- not much power should be needed.
Take a look at some of these amps:
Alpine MRP-T130- $109.99 - The Zeb
Here Are the specs:
http://ecominet2.alpine-usa.com:7777/pls/admn/item_info1a?p_item_name=MRP-T130&p_category=40&p_subcategory=120&p_main=10
GM-X552 $ 109.99 - The Zeb
50x2-channel Amplifier
http://thezeb.com/caraudio/pioneer.html
Rockford Fosgate Punch 100.2
100 W RMS amplifier $149.99 - The Zeb
Try these for a start.
Take it easy,
-zane
723
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
988
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
liwaj79
liwaj79
fremont ohio
zane
audiobaun
    May 19, 2024
    May 19, 2024
