OP
You want to avoid compression completely without losing cone control?.. 6 1/2" square with your power... that's what I'd doSo a 6 inch aero port at 16 inches long is fine lol? I'm so confused.
---------- Post added at 02:26 PM ---------- Previous post was at 02:25 PM ----------
What is that program called btw?
what would you recommend a slot port width and length? i still would like 32 hz tuning.no thats a tad high i use fps he used meters u want air velocity under 100 fps.. his is showing u at like 120fps with 6" port., i thought 6"would be good but it's the power u are running thats puts it over the recommended air speed.. u would need 8" port maybe or slot port to keep u around 70 or so fps.. if u were only using 1/2 that power it'd be fine..
Yeah 8" port... listen to gramps... he's the resident expert... lol!no thats a tad high i use fps he used meters u want air velocity under 100 fps.. his is showing u at like 120fps with 6" port., i thought 6"would be good but it's the power u are running thats puts it over the recommended air speed.. u would need 8" port maybe or slot port to keep u around 70 or so fps.. if u were only using 1/2 that power it'd be fine..
