Need help with kicker comp r 10 inch 4 ohm sub
  • 2
Ok...i jus want to put a single kicker compr 10 4 ohm sub in my car....i dont want super bass...ive had that b4...i jus want a regular setup...if anyone can help...what amp would b good for this...i know that wiring my sub in a parrelel can make it a 2 ohm load...is this possible with one sub...please help...these are dual voice coils
One of the amps im looking at is the cx 600.1...it can b run at 4 ohms for 300 watts n 600 watts at 2 ohms...the rms for the sub is 400 watts
You'll be fine with that amp.
People question it because the sub says 400 and the amp is 600....scurrred they don't wanna blow it. Trick is getting the gain set right and set it a little less if the sub sounds like it's bottoming out. That's good solid power there. Oh and clean signal/power is key.
So having the switch at 2 ohms it would b running at 600 watts....ive had systems in the past...i jus never hooked them up...i always had people set them up for me...jus wanna get the right stuff...n thank u for answering me
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
514
11
882
silva78644
silva78644
Lockhart. Texas
silva78644
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
