need help with sub sound!!
BacksideUSA
ok, i'll try and make this short... i recently bought a new system and just completed installing it. the subs are loud, but don't sound like i expected them to, especially at lower volumes. i have a kicker zx750.1 mono amp pushing 2 10" kicker cvt's in a sealed box under the back seat of my silverado. i think i might know the problem, but i'd like to hear some opinions. the cvt's are 2-ohm subs, so the only way i could wire them was in series, creating a 4-ohm load. According to my amp manual, the amp is only pushing 375W x 1 at a 4-ohm load.
So, if i get the 4-ohm cvt's, and wire them in parallel, to create a 2-ohm load, will that make the difference that i'm looking for?
I believe that the LC2i has a fixed subsonic filter at 33hz, that will affect the low end too. THe LCi2 pro has a set filter at 22 hz, better...
28
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
BacksideUSA
BacksideUSA
Seal Cove, ME
Epic0318
    May 18, 2024
    May 18, 2024
