need help
  • 2
john_doe_318
i need general info about subs they say db drive speed series sp10.1 but the pic i find wen i Google it isn't my speakers(have 3 tens) and the specs dont seem to match i had the 3 subs bridged to a 1600 watt amp (xterminator 1600.2) and sounded great but the amps ground wire burnt.and now i have a bigger amp kit 4gauge only had a 8 prolly was the problem.and need a amp sugestion and wiring diagram please ps im sorta a noob i have hooked up a few systems
sounds like your subs are dual 4 ohm which if you wired them up to that 2 channel amp you got a 2.67 ohm load [bad] for that amp .that amp needs 4 ohm bridged .so 2 subs will be fine if wired right .as far as specs you'll have to keep looking ,prolly older versions of the same models
512
878
870
john_doe_318
john_doe_318
bossier city
john_doe_318
maylar
    Jun 2, 2024
    Jun 1, 2024
