Need opinions and info on sail panel tweeters and speaker amp
  • 1
I currently have a 2005 Mazda 3 sp23 and I currently have a kicker compr 12" sub with an Alpine amp, pioneer A-series 6x8 in front and rear, a Kenwood dpx303mbt head unit, and factory sail panel tweeters. I wanted to put a kicker keysmart amp to the speakers but do I need anything for the tweeters? I will probably replace them later down the line but I am learning as I go with wiring everything together. Also what do I need to do wiring wise for the keysmart amp?
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
116
185
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
138
492
JustYourAverageImport
Sadler, Texas
audiobaun
    May 19, 2024
    May 19, 2024
