Need opinions on this build, WinISD.
  • 3
I designed this for a buddy of mine and plan to build it this weekend, I was wondering if any of you can point out anything obvious that I may have over looked. (3) Skar SVR-10 D2's build.
  • (3)SkarSVR10.zip
thats all the responses i get?
How about posting actual pics?.. I'm not inclined to download a Zip when its easy to post actual pics or a screenshot.
And Winisd needs setup to use...IME understanding comes thru experience... AFTER learning to set it up and thru real world use
Lol... ALL they worry about port velocities I swear... vehicle/airspace/power.. and port matters sure but finding what works in your instance MIGHT take some experience. I don't see a vehicle listed, or power/planned-load? for that matter. No goals... only a FB question for the group... clickbait.
SOME people can help you I'm sure... but when you ask a vague question I for 1 won't respond to it or a wishful unicorn goal. I remember your Sa-10 enclosure, underseat and all it seemed to deliver. But if all you got is some 10's (SVR) and a mystery amp without vehicle... what do you expect?
There's a response
I did post actual pics, I zip is the WinISD project file. This is a build for a buddy of mine all I was asking was for opinions. If you would open the ZIP file which is the only way I could post that on the forum you would know that its all inside the WinISD file. You made yourself look like a idiot not me.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
114
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
98
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
435
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
336
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
745
apeterson26
Memphis, tn
apeterson26
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
