Need some build assistance for calcs and box size for Kicker 12" 43CVR124
  • 1
Croga
Hell
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the "ported" portion. Is it a 2:1 ratio? Its for a friend and they do listen to rap and hip hop and rock as well. At what frequency should it be tuned to? In addition Kicker specifies enclosures from 1ft^3 - 4.6ft^3... where should I be at and what ratio for the ported part. Also, based on this calculator
at 2 drivers / xmax of 14 / freq at 25hz I should have a min diameter for a round port at 15.07"... but not sure on what to input for port length. (I assume I ran that calculator correctly, maybe someone can verify). The box is basically going to be a blow through into a truck cab. Thx!
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
867
JL has some slim subs, maybe one of those will fit. Alpine has some pretty small amps, you could put that/those under the passenger seat? i like...
931
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
Croga
Croga
Hell
Croga
    May 16, 2024
    May 16, 2024
