Need terminal screws for RE SX!!!
  • 5
EnvEe 02
Built For Brutality
Im in need of the 4 screws that hold the wire in the terminals on my Re sx. Im not sure what else to call them but i think that might describe them enough. If you have any laying around or anything that might fit please let me know. I tried all the local stores and even home depot and ace hardware but cant find anything that fits.
either one of those places have them,, you must not have looked well enough
the only size they do not carry is a 7mm.. it is an oddball size.. so if it is that size that would explain it.. if its something else then they have it
OR .. talk to david moore.. http://www.fixmyspeaker.com
I have a 2006 Honda Odyssey with a 130amp factory alternator. I have done big 3 with ground to chassis and engine ground. I run a 2000watt RMS...
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
57
415
327
729
EnvEe 02
Built For Brutality
EnvEe 02
Long Island NY
SPLaudio
    May 12, 2024
Brendon Jenness
    May 11, 2024
