need2 subs and amp!! >600rms-ea
  • 6
C2 Audio threatcon 2 $109 each = $218
apsm 1500 = $125
Your total is only $343, you can get a more powerful amp like the bamf 4000 for $139 which should give you at least 1600watts at sonics or bamf 5500 for $229 which will give you at least 2kwatts
Refurbished - Power Acoustik BAMF-4000/1D-RB (ls-bamf40001d-rb) 4000W Max Class
presale on Sub 12" 600watt $109
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
I have 2 15" Diamond Audio CM3's D4, and a LNIB MB Quart ONYX 1000.1. I could sell you this whole package for 300 shipped. They take the 1000 like a champ, in manual it reccommends 300-500 rms each.
16
987
404
533
812
Look at the Alpine Type S subs.
19
Only The Best
Only The Best
texas
TreyE
    May 16, 2024
    May 16, 2024
