Needing Amp recommendation's
  • 2
Infantrysc87
First off I'm new to this forum and I believe it will be very helpful thank you all in advance!!
I have a 2006 Tacoma pretty runner double cab I was needing new speakers so I had
Kicker Cs693 installed in the front door panels and
Kicker Cs65 installed in the rear door panels
They are hooked up to the factory radio and I'm needing and amp I'm thinking the best setup would be 75-100rmsX 4 channel amp any help would be very appreciated
step 1 is to replace the head unit with an aftermarket head unit that offers tuning features such as time alignment, crossovers, and EQ. I highly recommend the Alpine CDE-HD149BT but the 148 and 154 are good alternatives.
step 2 is to add a good amplifier to power the speakers. there are many options, but for the double cab there are few locations. compact is key and you can locate a compact amp in the storage area under or behind the rear seat. A Massive Audio NX4 is compact and powerful. An NX5 would give you a 5th channel for a future sub.
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
890
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
6
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
152
6
385
Infantrysc87
Infantrysc87
Ft Bragg Nc
Infantrysc87
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
