New cab 7k
Hertz at one time along with a few people couldnt recommend proper fusing techniques. I showed them nec wire ampacity ratings and sections on properly fusing and they lost thier **** saying i dont belong here etc...It was epic.
Is the same thing over and overi present a Theory and back it up with my own testing then I show other test but they say I can only post links I can't do explaining without legs and I'm always explaining to these douchebags how stuff works they tell me I'm wrong so I provide third-party information..
I was joking about them I use the least as possible, I like fire
Sent from my SM-G935V using Tapatalk
Da fvck? It wasn’t me.. it waa boomin that u were beefing with... your so fvcking stupid you can’t even get your shlt straight. I don’t use any fuses at all.
know one here even had a CLUE how to properly fuse. no-one still does. maybe 5 people. even after countless times I've showed them.
Since you claim to be the "god", the ,holy almighty, on here, why don't you show us the proper way to fuse. A pic...not continuing to run your mouth. Because the way I see things on here, is the right way. You insist everyone else is doing it wrong. I wanna see your way of fusing.
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
bamaman
bamaman
Phenix City, AL
Boomin_tahoe
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
