New set-up. Opinions
  • 3
Probably going to be trying some 15's out. Maybe 3-4 of them. In the past, I've liked the sealed sound, but not opposed to porting. Whichever would sound best in a large suv. Price really doesn't matter, but this is a daily driver, not a comp vehicle, so didn't want to go over board. Would love to do close to 150 off of music. Was considering:
Sound Qubed HDC3 - 15 but heard the glue points don't hold well.
Obsidian 15 - Havent heard much about em'
Maybe some high end SunDowns
Any who, what would you guys recommend? Probably end up putting $1k-$2k into two amps, so power shouldn't be an issue. Maybe a Soundqubed amp or two. Is there any other subwoofer I should be considering that is comparable to the HDC3's?
Also, how should I get the enclosure built for 3-4 15's? I think 3-4 subs on good-great power should be plenty loud. Of course a couple of batteries and alternator. Thanks in advance.
Amps will determine subs power or vice versa if you want a 150 on music it's not gonna be cheap you'll need maybe 2 big alts. Lots of batteries and wire but all the subs offered up will do the truck I guess it just boils down to cash. Box needs to be roughly 20^3 subs up port back. You can do interchangeable ports as well
6
498
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
850
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
902
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
SQUIRRELMASTER
THE SOUTH
mylows10
