New Setup?
Right now I have a Crescendo BC2000 and 2 XFL 12s wired at 1 ohm. They are in a box that is tuned to 33hz and 15in tall x 37in wide 21.5in deep. Is it worth my time to build a new box with 2 15s firing upward on the same amp? Would I notice a difference?
It's my understanding that firing up would decrease output.
i thought that all depends on vehicle. ive read SUVs sound better subs up port rear.
ya your right.
i have a suv and have tried all position of my box.
the best is sub up, port back.
but op did not say what car/truck he has.
so what do you have?
Got the 15's already or going to buy them? Can you fit 18s? Bigger box with more cone area will be louder.
I only have what I listed. I am willing to sell what I have to get something else but cant really buy a bigger amp since the bc2000 is pushing my alt right now hard even with 2 batteries after 1 song full tilt I see 13v - 13.5vs
building the box myself and idk about my budget yet. With only 2k rms I didnt think I could get into too many expensive subs.
Cheapest solid option would be HDS315. Can do HDC315, which will give you room to do 4k amp later. You can do the AB XFLs again as well or some death rows.
Death rows are too expensive 400 for one is a bit much. I am liking the HDC315 but idk right now if I am going to go 4k later. So I would rather just get subs that will fit my amp.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
600
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
922
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
roudabout6
Alexandria, Ohio
roudabout6
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
