New SSA Dcon almost ready...
  • 6
denim
SSAudio.com
33,767
158
SSA HQ East
Photos are done, specs and enclosure info will be up soon. Below are shots of the new Dcon 10, it is a shallow mount. It is still a great SQ option that blends really well, and can have authoritative output on modest power. The newer design has greater cooling and more motor force along with a little more power handling and enclosure flexibility than the original Dcon.
Sub Woofers - SoundSolutionsAudio - DCON - SSA STORE
looks śexy //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif :emb:
Ssa has to have some of best looking subs, with performance to match, love how the motor is extended like that.
Why thank you. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Have any info yet? Definitely interested.
Same here. I may have a couple of installs coming up soon that this would be perfect for. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here are the PRE-PRODUCTION specs:
DCON10
DCR 7.8 Ohms (D4 wired in series) 3.4 (S4 coil)
FS 29.6 Hz
QMS 4.51
Qes .31
Qts .29
Mms 111g
Vas 35.0 l
SD 310 cm^2
BL 22.8 15.05 (S4 coil)
SPL 86.5 1W/1m
DCON12
FS 28.1 Hz
QMS 4.98
Qes .34
Qts .32
Mms 136g
Vas 78.1 l
SD 480 cm^2
SPL 89.2 1W/1m
DCON15
FS 32.5 Hz
QMS 5.66
Qes .45
Qts .42
Mms 148g
Vas 149.2 l
SD 810 cm^2
SPL 92.4 1W/1m
No problem. I understand. Also if you could tell me how much sealed or ported air space they need. And what you would safely consider a daily rms range. If they will fit id like to put 2 10s in my truck. Thanks.
Enclosure wise, they are not far off from a mix between the original Dcon and the Gcon. Not knowing listening habits or power, for a pair of 10's sealed, I would do around 1.5 cubes with maybe a pound or so of polyfill, and ported I would aim for 2.2 cubes tuned in the 31hz range.
Power wise, 400 is plenty. I pushed it pretty far past that, but that was more for abuse testing. So going over 500 is not really needed, 300-400 is plenty and a nice sweet spot.
Do you think they would be ok with 1.05 sealed? That's about how much room I will have under the seats. Also I've got about 6" mounting depth to work with. Do-able?
That is tight, but could work with some polyfill/acoustastuff. Is that mounting depth allowing for space in front of the cone?
denim
SSAudio.com
denim
SSA HQ East
denim
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
