New to car audio and need recomendations
  • 6
lgnbarnard
Texas
Hi,
I drive a chevy silverado '07 crew cab and need help. I am looking for one 10" sub with good quality and good enough bang. I have the bose audio upgrade and don't want to over-run the audio with just bass and don't want loss of quality. I have been looking at the CompVT | KICKER shallow mount 10" and the box 07 & Up New Body Style GM Crew Cab Single Downfire Box. Although i ran into Kicker 10TCVT102 Sealed truck enclosure with one 10" CompVT subwoofer at Crutchfield.com and I'm not sure how that would fit in my truck or the quality of it as well. Also, I need help finding an amp, I was recommended a mono JR audio 500 watt amp but I have no idea where to start finding that and a good price. I need to know what else I have to buy as well, such as a wiring kit and what kind. And on a final note I need help finding a good place to install. I heard Fry's is a good place but I'm not positive.
Thank you for any help and taking the time to read my post //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
edit: I am also confused on where the Kicker 10TCVT102 fits in my truck, does it go under the seats in the same spot as the custom box?
Hi,I drive a chevy silverado '07 crew cab and need help. I am looking for one 10" sub with good quality and good enough bang. I have the bose audio upgrade and don't want to over-run the audio with just bass and don't want loss of quality. I have been looking at the CompVT | KICKER shallow mount 10" and the box 07 & Up New Body Style GM Crew Cab Single Downfire Box. Although i ran into Kicker 10TCVT102 Sealed truck enclosure with one 10" CompVT subwoofer at Crutchfield.com and I'm not sure how that would fit in my truck or the quality of it as well. Also, I need help finding an amp, I was recommended a mono JR audio 500 watt amp but I have no idea where to start finding that and a good price. I need to know what else I have to buy as well, such as a wiring kit and what kind. And on a final note I need help finding a good place to install. I heard Fry's is a good place but I'm not positive.
Sounds familiar!
I was looking at doing similar stuff back in late November, but decided to put off doing anything for a bit and spend my time here, and elsewhere, reading/researching.
Sure glad I did....you can do a lot better than a prefab box and Kicker CompVT's...and for the same price, or even less.
There are much better subs for going sealed (Dayton HO's just as one example), and I would suggest a 12" or even a couple 8s for a crew cab truck. The right 10" will be okay, but you aren't going to get very loud with it...
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
894
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
521
16
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
749
lgnbarnard
lgnbarnard
Texas
Bettr n' Revrse
    May 24, 2024
    May 23, 2024
