Newbie Clueless Need Some Guidence
thatguy
Toronto
I just started learning more into car audio and for the past couple years, i thought a new it all.
Anyways ill get it to the details.
Hardware
Headunit - Pioneer DEH-80PRS.
Components - Focals 130VR Component Set. Manual
Subwoofers / Mid Bass - 2 JL Stealth boxes (Free to Air Rear deck Lid) with2 Peerless SLS 8 830667 Manual
Amplifier - Alpine PDX 4.150 Manual
I listen to mostly a little bit of everything expect Rock Or Jazz.
I have no clue what to do on setting these up specifically the AMP. My main problem is that, if i bridged the rear in to a 4 Ohm (8ohm single each), will the amp be able to handle it at 300x1@4; Whiles handling my fronts without an issue?
What will be the best for me to get the most out of this setup. Should set up the amp for LPF or full? And the fronts leave them at HPF or Full? I'm so clueless.
Lastly, i don't understand these switches. It doesn't explain what i want to achieve.
basically i want 2 bridge the rears whiles leaving the fronts alone.
English is not my first language so please bare with me and I'm really new to this. Just trying to soak as much information.
thanks for reading
this amp can handle 3 ch operation, with two channels bridged to one and the other two powering your fronts. If you wire the subs in parallel (like you said), that's a 4 ohm load for the bridged channel, which will supply 300watts rms total and 150 watts to each sub. set the switch to lp for the subs to only allow the low frequencies to go to them. set the switch to hp for the fronts to block low frequencies. set the crossover knob to anywhere between 60-150(whatever sounds best to you). those front speakers only handle 50 watts rms but this amp would feed them 150, so adjust the gains by their sound(turn down the gains to reduce the power going to them). I don't know how much english you know, but if you have any questions about what i just typed just ask.
I've noticed that my skills seem to be a bit out of whack in the Char Generator -actually have received a few skill loading errors- so I've tried to edit them so they're more correct - not sure I've succeeded though. A few skills I've focused on trying to max are my Use Magical Device, Perform and Concentration.
CAR OBD2 SHOP
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
876
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
Wow. That's a nice truck. Where I live there are few cars and trucks that use only one amplifier to power the speakers. So already noticeable...
6
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
thatguy
thatguy
Toronto
Marilyn Horne
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
