Newbie help needed - amp/sub
  • 2
Chippa02
CarAudio.com Newbie
Hi All,
New to tackling some basic improvements to stock system and learning for myself along the way but need some help from the more experienced people 🙂
I have an older 4 ch Pioneer bridgeable amp ( 1000w class D - ice) and wanting to hook up sub correctly. I have wired in to rear speakers a basic line level converter with RCA's to amp.
I have read/watched many vids regarding adjusting gain with multimeter to achieve an acceptable voltage output from channels.
My question is if I bridge two channels for sub will my volts equation change if bridging ?? I.E amp is 75w RMS per channel and sub 4 ohms for one channel calculation...or do I have to use 150 x 4 to get correct volts calculation.
Amp has two gain controls (A & B )
Hope it's not a dumb question..thanks in advance for any advice
Cheers 🍻🍻
Use the sub's ratings for this. If it is 750w rms, 2 Ohms. 750x2=1500. Square root of 1500=38.72v. That is the A/C voltage you will look for coming out of the bridged channels. Gain A should control fronts.
Hey thx for the reply....every video I've watched has always used the RMS rating from the amp per channel...not the Sub which in my case the sub is 250w RMS /750w peak power ???
Yeah, I do not understand that thought process either. The sub is the one that will be in danger of failure, so using it's ratings just seems like the logical thing to do. Maybe it is to find the clipping point but you need more than a multimeter for that. On that note, that is why it is optimal for the amp to be able to handle at LEAST the RMS rating of the sub/s you are using. This will keep it far from clipping territory. Just practicing restraint and controlling the volume is not enough. That one song will eventually play and one will crank it up.
Ok thx for the explanation, as I'm only running the sub off the amp I'll set it up for 2 ch mono (300w x 2) and use 250rms (sub) x 4 ohms to get my volts calculation to set the gains..
If I've missed anything please let me know...thx for your help 🙂
Adjust the gain on the amp to 0.5v.
The amp gain adjustment goes from 0.4v - 6.5v...(max 26v)..does not matter where I set gains, the sub doesn't move much.
One thing I did notice is when I only had one rca plugged into amp the sub actually seemed to work better...not a huge jump in performance but definitely made a difference...
Did you plug into the Front RCA inputs? Also, is the amp 150RMS bridged per channel? If it is, then you will have to target 24.5vAC per bridged channel to avoid clipping.
Are the subs single 4 Ohms?
The HU has no RCA outs hence using LOC.
Tapped into left and right rear speakers to connect LOC, used 9v battery to check correct wiring +/-.
Ran 50hz test tone at 75% vol on HU and flat EQ etc...used MM to check LOC output voltage (0.5v).
Amp is Pioneer PRS 4200FD 4ch...bridged in 2ch mode is 300w x2 which is how I have wired sub...
Sub is 12" Alpine Bass 250rms SVC 4ohm
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
892
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
Wow. That's a nice truck. Where I live there are few cars and trucks that use only one amplifier to power the speakers. So already noticeable...
6
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
Chippa02
CarAudio.com Newbie
Chippa02
Western Australia
Chippa02
