Next Year Blowthrough Build 8 sa 12's
Mazdafi
Hey Guys,
Just thought I would post up my future re-build for the Mazda.. The subs will be Sundown Sa 12's.. I have decided that I'm done with the whole wall thing.. Let me know what you think..
And if anyone wonders how i intend to mount the subs, this is the idea i have come up with.. An access panel..I will be using weather stripping under the panel to make it air tight..
Aound 9.2 cubes after displacment at 36hz, I know is alittle on the small side but for the room i have thats what will have to do..
Wouldnt it be better to go with 6 subs then? Maybe you could get the correct size box that way. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
926
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
Mazdafi
Mazdafi
Union Gap, WA
power-fanatic07
    May 12, 2024
Brendon Jenness
    May 11, 2024
