bldunn
Hi guys,
I am new here of course. I am audio-stupid but look to you all to get audio-smart. I bought this amp with no name, that he said was 1,000 watts. The sticker on the back side of the amp shows "dx1500.1" so I assume it's 1500 watts. However, it only has 4 fuses that I see on the outside of the amp which are all 30 amp.
The sub I bought from the same guy with the amp was a 12" kicker comp r. And today, after only 2 days of even having this system the kicker is gone. It is frozen stiff as a board. I can still hear something coming out of it when I turn the music on but its more like a faint paper or metal rattle. No movement whatsoever to the sub. So I am waiting on my Power Akoustic MOFO-124X to come and want to ask, is dual 4 ohm what I should ideally run on this no name amp being that I have no idea what the impedance of the amp is? The kicker was set to 1ohm on the selector which was 1ohm or 4ohm. I had to buy a new box for that sub right after getting it from the guy I bought it from because the box he had it in, with stripped out screws and what not the box itself was rattling from air escaping around the sub.
My amp gain and bass boost were both set almost to nothing on the amp, at the time that it blew. But when I first installed it I kept jacking with the gain and think I had already damaged the sub that day I hooked it up and today it just finished it off. The song I was bumping when it happened was "I know" by Yo Gotti. And I think I had adjusted the bass on my stereo (factory toyota stereo) to 2, or 3. The smell I kept smelling when I think the coils were getting really hot smelled more like leather to me than anything else. It didn't smell like burned wires or metal or anything. Which is why when I first smelled it I chalked it up to outside air smell.
So how should I wire up this dual 4ohm sub I have coming? Should I wire it to 2ohm load on the amp? The amp is monoblock, with 2 outputs but I am guessing that it is internally bridged so it wont matter it I do what would be bridging between the 2, or hook straight it into 1 of 2 outputs, all same in the end, right? I really wanted to get the skar audio ZXVx3 I think it was, but couldn't let go of $359.99 to get that right now so opted for the cheaper MOFO-124X at 1500 watt RMS and 2700 PEAK. Good move?
