Noise on sa8 v3 sundown free air
It's probably normal noise, just about every high excursion woofer I've played around with free air has a lot of suspension/air venting noise. Its normal and is no longer audible when mounted in an enclosure. This includes some of the older SA8's.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Herreraxto
Herreraxto
Texas
Massive spl
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
