NOOB AT CAR AUDIO NEED HELP ASAP
graysole1123
IVE GOT A SYSTEM SETUP IN MY CAR AND QUESTION CAN SOMEONE EXPLAIN OR HELP ME AND TELL ME WHY DOES THE BASS DIM WHEN I TURN UP VOLUME IVE GOT A CAP HOOKED UP CUZ I THOUGHT IT WAS DRAWING TO MUCH POWER BUT THATS NOT THE CASE EVERYTHING WORKS I KNOW MY POWER QWIRE IS BIG ENOUGH IVE GOT A 0 GAUGE WIIRE POWERING CAP AND AMP BUT STILL GO TO TURN UP VOLUME AND BASS FADES OUT WHY IS THIS AND HOW DO II FIX IT
UPGRADE EXACTLY IVE GOT 0 GAUGE POWER WIRE FROM BACK TO FRONT AND HAVE GROUNDED AMP AND CAP IN TWO SEPERATE SPOTS DO U MEAN LIKE UPGRADE ALTENATOR
What car is it? That'll make a big difference as well. Small cars have small alts, small batteries, and small cables (probably 8 gauge) connecting them. So when you run 0 gauge to your amp it's going to pull out all of the power, and your cars electrical system can't provide that much juice so your amp fails.
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
graysole1123
graysole1123
ontario
Marve_Lous
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
