Noob didn't quite get it in the 101
AK_stealth
16
Virginia
1000w amp mono supposedly is 700watts at 2 ohms / 500 w rms dual VC subs 2 ohm /
Wired like this to create a 2 ohm load. My noob question is ....Do both subs get the 700 watts? Please forgive me folks just looking for a straight answer.
Sent from my SAMSUNG-SM-G930A using Tapatalk
You're going to wire at 2ohm or .5ohm
Match those SA's with a Sundown Amp. Don't get Hifonics unless you NEED to.
At .5 ohm how much distortion is there? Plus I wasn't trying to break the bank what's wrong with hifonics ?
I agree... the recommended enclosure has SOME rise and it looks to take 1.6K to get around 1K... boy!.. that's a tricky port too with a slot!.. don't cheap out on the amp...//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
There won't be any distortion if you tune it clean.
Hifonics has exaggerated ratings and they don't last very long.
what did I do //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif ??
Absolutely nothing. the fact that 2 ohm was mentioned.........
op gonna have a tough choice on finding an amp at 1/2 ohm.
Nothings wrong with 2ohm. Just depends on your goal. Implying the goal is to get no power after rise //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
SAE 1000 would be the amp I'd run with those subs.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
AK_stealth
AK_stealth
Virginia
shredder2
    Jun 1, 2024
    May 31, 2024
